Hello,
I just started working on this project after putting it off for a few years. The idea is: Portable, battery powered, tube shaped, stereo, two way speaker with built in subwoofer, that you can carry with a shoulder strap. The sub will be Tang Band W5-1138SMF, but the rest of the drivers Im not sure. Even after hours of searching I wasnt able to find any affordable miniature two way with good reputation that also has both drivers easily buyable. Currently my only idea is to use Helium (Dayton ND91-4 and Dayton ND16FA-6) but Im worried that it wont be loud enough... or is that going to be a universal problem with small woofers?
All tips and insight would be much appreciated.
still apllies today: Hofmann's Iron Law: three parameters that cannot all be had at the same time. They are low-bass reproduction, small (enclosure) size, and high (output) sensitivity." Hofmann stated that designers could pick two of these three parameters, but in doing so, it would compromise the third parameter.
WHat about 2x W5? end mounted on each side, mechanically link for push/psuh vib. cancellation. SImilar to the old *boom blasters' from back when.
And use fx. a faital 4FE35/42/44.
You will have gaiend a lot of output capability, but sub will have to play higher in freq.
