Polyverb instrument level output to line level (for mixer return)
Hello, hoping someone may guide me to the right source for this.
My band just bought a Polyeffects Polyverb convolution reverb pedal to be used for typical mixer send/return duties. It works adequately but we are diming the output level to get a just acceptable level. I'd like to include an interface that would allow a greater output range. I see that most "instrument to line level" seem to assume that the instrument is a high impedance source such as a guitar pickup. I have to assume that the output to this device is active and of a much more lower impedance as found in active devices (50-200 ohms perhaps?).
I'm a senior electronic tech during the day and build my own pedals, mic pre's and guitar tube amps so figured I might be up for the job of building a high quality low distortion "instrument to line level converter" that is compatible with the requirements of what I need this to do.
Would anyone be aware of a schematic or good source for something like this? I'm assuming the use of a very high quality OP amp which I'm fine spending the money on. Or, if there is an off the shelf device I'd take a look at that, too. The Polyverb IR reverbs are very high quality and I'd like to maintain alot of the fidelity that the pedal is capable of.
Thanks for reading and input all,
Best,
Phil D.
