Plunger pincer lead for digital multimeter (high voltage 400+ V)
My oscilloscope lead is rated > 600V and I like the plunger pincer lead when dealing with high voltages versus alligator clip or using the pin with my hand.
All of the plunger/pincer leads I have found have a much lower 250-300v rating and not ideal for some of the voltages in a tube guitar amp.
I have alligator clip multimeter leads that are rated higher than 300v, but I feel more comfortable with the plunger / pincer ones in tight spaces.
I did find some that exist but they were not in stock.
Am I just searching in the wrong places/vendors?
Can I just use my scope probe on my multimeter?
My scope has a multimeter in it, but I'd like a second verification since my scope is not top end and there are times you are using the scope and still want a dmm reading.
I should have stated I "low cost" ones as some of the ones I found were north of $100, but going directly to both probe master and fluke I see some way more reasonable options. I know that was a "rookie" question, but I am thankful for the replies.
I use the 8000 series on all 3 of my nice meters (Brymen/Fluke) and couldn't be happier... the 87V came with PVC leads. They went directly to the "just in case" box because I couldn't throw them in the trash where they belong. I like Fluke's silicone leads but PM are a way better bang for the buck imo. Yeah, you can save a bit going direct.
Yes, digging into the specs the Probe Master one selection comes with 8050 sprung plungers that are rated at 600V which will work fine testing HT, plate, screen and other higher voltages.
I concur on the suggestion to not skimp on test leads. Both from the "redundant economics" standpoint where you will end up replacing junk leads many times over. But also why would one want to skimp on risk or damaging equipment or your own safety too?
Thanks for all the input.
Reactions: rayma
