Pll
Please suggest which PLL I should use for audio over 1394.
{ One of the input to this PLL is a pulse signal. This pulse signal is generated when the timestamp received mathces the local cyle timer. Typicaly this signal will be of 4KHz. The other input is the PLL output divided by 8. The output which I need is 32 Khz or 128 Fs where Fs is 32 Khz.}
