PLEASE HELP! Insulating Transistors Electrically from Heat Sink
Most TO-126 are insulated package - no isolator required.
The TO-264 need a silpad or mica washer (as mentioned above). It can be difficult to locate mica washers for the TO-264 but you can use washers for TO-3 and cut them to size. Use a hole punch to make a new hole.
i just thought about cutting some wax paper/parchment paper to do the job. anyone know if that will work?
I used regular white printer paper once (long ago) when I didn't have anything else. Smeared it with heatsink compound and it seemed to hold up pretty good, although I didn't leave it for long - just to test the circuit.
Truly, you would be better off with proper insulators. As Sy pointed out, they are a lot cheaper than the devices they are isolating.
Can anybody explain the pro's and con's of using silica pads over mica washers and thermal grease? Should you use thermal grease with silica pads? I have always used mica insulators with grease but latrly I have noticed pads being used and it looks like no grease. So the pads don't need grease?
The silica pads are easier to use but at least the comon ones don't transfer heat
as well as the mica. There are much more expensive silica pad type ones in the $1
each price range that do transfer heat a lot better but for a price performance standpoint mica is still hard tobeat.
