Please help identify this old Woden transformer
Hi diyA Folks
Can anyone shed light on this transformer? It's been in my parts bin for nearly 40 years and I seem to recall it was my father's before that. I'm wondering:
Is it an "auto transformer"?
What could it have been removed from?
Is it of use for tube (or other) audio?
How does one generally wire it up / use it (Australia = 240 line voltage)
Thanks for anything you can add ...
Simon
If it would be an autotransformer, so just one winding with many taps, than you would have to be able to measure resistance between all taps.
My guess is that it is a normal transformer with many possible voltages on the primary side and 0-5-10 V (at a maximum of 6.35A) on the secondary side.
I'm not 100 % sure what the "C" means but if there's resistance between "C" and the 100-115-120-160-200-230-250 taps I would think that "C" is one of the two taps where the primary voltatge has to be connected to (while the other connects to one of the 100-115-120-160-200-230-250 taps depending on the value of the mains voltage).
Ofcoure there should also be resistance between the 0-5-10 taps (but not to any of the other taps).
