Does anyone have the plans for Visaton Cheap Trick 142 loudspeakers? http://www.speaker-online.de/bauen/ct142.htm They look like a nice TL enclosure. Thanks in advance.
Wow, I think I must have built four pairs of those! A very long time ago though. They are great speakers, excellent bottom extension (as you would expect from a TL) not really tight bass though.
I think I don't have the issue of "Klang & Ton" anymore, as it is from quite a while ago and I have moved four times since that time (and "reduced the inventory" everytime). I will have a look around in my "archives" and I will let you know if I find something.
I think you might have better luck trying to e-mail the people at "Klang & Ton" magazine, you can probably order old editions of the magazine and if not, they might send you a copy of the plans.
There are probably other (more current) designs floating around this forum you could also try.
Good luck,
Jarno.
Good luck,
Jarno.
Sorry for the double post, but I can't seem to find an email address of Klang and Ton. Could someone be kind enough to provide it?
Thank you very much, I already found the link: http://www.visaton.de/vb/showthread.php?threadid=5293&highlight=ct+142
Although I don't speak german, the plans seem self-explanatory. Once again this forum proved to be the greatest. Thanks guys.
Don´t forget to post your results.
Love those cheap tricks.
Nice to your ears and kind to your purse.
What stuffing material for CT-142
Hi Jarno
Similar TL Scan-Speak " Event" of Audiocomponents is stuffed with a mix of egg-crate foam "Pritex" and wool.
What would Visaton´s NG42 looks like?
TIA
🙂 JC
Hi Jarno
TIA
🙂 JC
Stuffing a TL
Hi JC,
I think we used different materials for each pair of these (I built 4 pairs together with some other people) depending on what we had laying around. Pritex, felt, rockwool we scavenged from building sites, different types of foam. As to stuffing, I think a TL only needs to be lined with a thin layer of damping material (felt). We only stuffed the room directly behind the speaker and the area near the port (to make sure you don't hear any nasty reflections). Probably, the TL experts on this forum have a more educated opinion on this.
Greetings,
Jarno.
Hi JC,
Greetings,
Jarno.
I don't know who's the designer, but I want to say, that if you want to build those speakers (which aren't up to date any more) you should try and change the DT 94 to G 20 SC.
The DT 94 isn't that good any more and the sound quality of it isn't really pleasant.
The G 20 SC is a shielded tweeter, which sound qualities are very good for such a low- budget- chassis.
But then you have to make some changes in the xover...
Exactly what I was thinking about.change the DT 94 to G 20 SC.
The DT94 is known to be a bit harsh but of course the whole project will be more expensive then.
If you wanna use the G20SC you could just ask at the Visaton forum for alternative crossover solution if you don´t know how to design yourself.
Usually they also respond in english.
Thanks for the advices. And yes, I am on a budget, and the price leap for G 20 SC tweeters is too big for my purse. The price limit is something around 150 euros for all the drivers (2 woofers + 2 tweeters).
Someone said something earlier about better (newer) designs. I guess he/she was referring to TLs using cheap Visaton drivers. If that is so, I'd like to know something about that issue.
- Plans for Visaton Cheap Trick 142
