If this is a ZED amp (mentioned online), email them to see if they will offer any suggestions.
If you have any IRF3415s, you might want to try them. They've proved to be good general purpose FETs for amps with all N-channel outputs. I used them in a lot of MTX amps.
I will try the 3415’s . I talked with Zed .
Mr Mantz said I could use something like the 540N .
He was driving down the road when I spoke to him so he just told
Me that the 540N would work along with several others as long as it’s rated for 100 volt and the other specs are close to the BU102 specs
