Planar 78 ?
I assumed Rega don't have a special 78 motor.
Most mono cartridges now have stereo pins but are internally shorted.
So the RB250 should be entirely standard.
If the arm is actually mono, then you'd need to desolder a link in the armbase.
🙂/sreten.
I just went and picked it up. Score for $60.
It lookes identical to the P2 except for the name on it. The clips at the cart are just soldered together, so that's an easy fix. I'll just have to turn a pully tonight on my mini lathe and I'll be rockin' out.
Thanks,
Rick
Anybody know what the motor RPM is?
I measured the motor pulley at 13.75mm and the platter pulley at 56.7mm, spining at 78 RPM gives me a motor RPM of 321.6. This dosen't seem correct. The motor pulley was a bit hard to measure, but I think I must be accurate within .5mm.
I also own a planer 78.
I asked rega if I could convert to 33/45. They confirmed that you can and sent me the replacement pulley for free - good of Rega. The actual pulley needed will depend upon whether you have a metal or plastic sub chassis.
The arm is the standard rega rb250 and has four wires already although only 3 are used with the 78 cartridge.
Don
My technician friend with oodles of 80s turntable experience on a lot of Linn and Rega has told me that the Rega's run slightly fast.... (IE not motor RPM but pulley /platter ratio causes greater then 33.333333333 RPM)
This makes em sound pacey but it is also said that the human ear is more sensitive to slow pitch rather then fast so the extra speed leaves a margin for fluctuation without falling below correct speed.
Perhaps contacting Rega is the best thing to do...
