i've an Opel Vectra DTI with a CD30 MP3 as headunite
i have made a line out from the headunite and i want to use it with this pionner but the problem that the Amp wont to start 🙁
after many houers on the net ..i found that i need a remote wire from the headunite to make the amp start.....
the problem that this is not possible caus it's not made to work this way
how to turn this amp w/o the remote wire ????
You just need to add a switch, relay, etc to provide 12 volts to the remote wire when you want the amp to turn on. Take the remote input to ground to turn it off.
BTW, that's a pretty good amp. I worked for Pioneer in the car audio division when that was produced. You have a nice amp there, hope it works.
Scott
Scott
hi...thnaks for replay
can i make jumper like this just 4 test
