Pioneer TS-W34C 12'' sub for a dipole
Hi
I've been looking for sub drivers locally and for cheap, to experiment (and possibly like the final result) with building a dipole sub.
This one is currently on sale, but i am not sure if it is good for dipole application. Its Qts : 0.64 and XMax is 28mm.
The fullest specs i could find of the driver are here:
http://bizrate.lycos.com/marketplace/product_info/details__cat_id--11940000,prod_id--7391392.html
I plan to build an H-baffle dipole, but to situate drivers horizontally (not vertically like in Orions) - is it ok, or its gotta be vertical?
Alex
I don't know where they got that QTS but I'm certain it's not right for that model,I don't have that model in my database at home (I do at work though) but I recall it being around .3, you can however use the "F" series in dipole, since they're designed for IB use and have a suitable QTS for dipole use.
example
Horozontal configuration will be fine.
Well, I decided to bite the bullet and get them (on special for $63 CAN (1US = 1.3CAN))
Comparing to my Peerless CSX series in my main speakers these look quite dinky and the downside is that Fs of these appears to be ~29Hz (is it really all that bad? , can i still get under 29Hz with EQ?)
Also It says on the box that they are for in-box use (i guess as opposed to in free air) - so thats another thing i am worried about. Overexcursion - is there a cure?
Qts is 0.65 so i guess its fine.
The cone got a thick plastic centre circle and thats what makes the sub look dinky to me.
The surrounding is foam and pretty wide, comparing to other subs i saw there.
I have a month to evaluate them and return if i dont like them. To protect myself from them blowing, while working in the free air, I got the extra 3year warranty (for like $25US extra for both), so I'm covered there.
I'm afraid to be dissapointed with those in the final H-baffled dipole, but i guess there is only one way to find out 😉 - is to try and see.
<Your comments here>
Alex
