Pioneer GM-H100 quit
Anyone well versed in these? I added another to my collection and when I hooked it up to test, it worked for about 5 minutes and then just shut off. So I started looking for bad solder joints (which I should have done to begin with) and of course the remote turn on lugs were bad, fixed that, but it still won't come on. I have no "SWD ACC" from pin 8 of the upc494, so I go backwards.. (amp is completely unhooked btw) and I'm touching up solder joints for good measure...I touch pin 4 of the TAB194Z chip and the relay clicked...so becuase i'm "not much to lose here" I hooked it up, nothing....so i touch the soldering iron to pin 4 again...and it comes on and plays... so would the 2 turn on lugs being bad have caused the TAB194Z to fail? Or what might I be missing?
Anyone have a thought (other than I'm an idiot...)
wow, thank you Perry. yes, it's grounded. (metcal soldering iron). I was just surprised that the relay engaged with no power or ground hooked to the amp. yes, the 8194 has the voltages in the manual present, it just appears to be dead. I haven't looked yet, but I assume given it's age, that IC may be hard to find.
ok, I went home for lunch and measured each pin. they are as follows. (with power, ground and both remotes powered.)
pin 1. 0.0v
pin2. 0.0
pin3 0.0
pin4 13.9
pin5 .011
pin6. 0.0
pin7.017
pin8 0.0
pin9 0.0
pin10 13.9
pin11 0.0
pin12 13.9
pin13 .033
pin14 13.9
pin 15 0.0
pin16 .001
pin 4 being at vcc can't be a good sign
