pioneer cd player deh-p6300 no power
hi am workin on this cd player and its dead,when i press the eject button i can hear a beep but nothing on the screen,i change the output ic and resolder some bad connection but still the same. ideas or pointers whould be appreciated
thanks
The most common problem on the head units with the faces that fold down of flip around are the ribbon cables. If not one else has any experience with this problem, I'd suggest that you replace the ribbon cable.
I'm assuming that you've checked all of the fuses and have confirmed that you have both constant and switched voltage at the power plug where it plugs into the head unit, as well as a good ground.
