"Piecewise" waveform arithmetics in ltspice?
Is there a way to combine several waveform arithmetic functions so that they would work at specific ranges of input x?
for example:
With values of x < -1 the waveform would be processed with function #1,
with values of x >-1 and <1 the waveform would be processed with function #2, and with values of x >1 the waveform would be processed with function #3.
the U() function can be used to turn on/off terms in an equation
my http://www.diyaudio.com/forums/software-tools/101810-spice-simulation-37.html#post1333137
sim uses the U() function to select different periods of a waveform for parts of the calculation:
V=u(time-{(ncycles-3)*period})*u({(ncycles-2)*period}-time) is unit pulse for one cycle of a waveform and can be multiplied by the funciton you want to select for that time range - other functions of I,V can be used as "window" control arguments
