Hi The issue I Have is that my IP is Telstra and has been for 5 years.
I have used the same method and phone for 2.5 years without issue unil now. So whaddup?
Are you working through a managed server ? I've had this issue at work where the IT guys have changed a permission setting.
testing.
ok that worked from my laptop...
Second from phone.
Second from phone.
how big are the images (KB) and how many are you trying to upload at a time?
I have had trouble when uploading multiple images at once especially if they have been on the larger side. I get the message about the secuity token.
Try adding one at a time (use the browse button and then click upload, repeat until you have uploaded all of them) You can try two then three and find the limit of what is working.
Tony.
Tony.
Cheers for the response. Never had issues prior with anything less than 2.5 MB
Process of elimination I'm sure it will be sorted
Thanks Again
Thanks Again
Yeah it's only been in the last six months or so that I've experienced a problem, and it isn't consistent. When it happens I just go back to one or a couple at a time 🙂
Tony.
Tony.
There's different limits on different file types. This is listed in the upload window.
asc 1.91 MB
bmp 195.3 KB
doc 195.3 KB
gif 390.6 KB
jpe 976.6 KB
jpeg 976.6 KB
jpg 976.6 KB
pdf 976.6 KB
png 976.6 KB
psd 976.6 KB
txt 195.3 KB
zip 976.6 KB
It looks like most types are a short MB max, and none are full 2.5MB.
asc 1.91 MB
bmp 195.3 KB
doc 195.3 KB
gif 390.6 KB
jpe 976.6 KB
jpeg 976.6 KB
jpg 976.6 KB
pdf 976.6 KB
png 976.6 KB
psd 976.6 KB
txt 195.3 KB
zip 976.6 KB
- Site
- Forum Problems & Feedback
- photos won't upload "security certificate absent"
