The secondary winding will be the one of lowest resistance, perhaps just an ohm or two, the primary will be quite high, several hundred ohms to a kilo-ohm or more.
And, of course, these DCR's have no relation to the circuit impedances.The secondary winding will be the one of lowest resistance, perhaps just an ohm or two, the primary will be quite high, several hundred ohms to a kilo-ohm or more.
Roger
