Hello!
Is the Philips CDM1 MKII a direct replacement to Philips CDM2? I know the CDM2 is the plastic version of CD1 MKII and share the same servo circuit.
Thanks!
Thanks!
From the pictures it seems the connectors are different:
http://www.ersatzteil.justone-schnepel.de/html/philips_cdm-1_cdm1.html
http://www.ersatzteil.justone-schnepel.de/html/philips_cdm2_cdm-2.html
oshifis said:From the pictures it seems the connectors are different:
You're comparing a CDM1Mk1 with a CDM2 there.
CDM1mk2 is die cast version of CDM2. I have run a CDM2 in place of a CDM1mk2 in a Philips CD880. Just needed to adjust focus offset and laser power pots.
