Philips Cd 304 MK II
I was using my Philips CD 304 as a transport to an home grown DAC(with 2 PCM63P decoders). Want to cut off the operations other than the Digital Output, of course I will still need the front control panel. If there some power supply plugs I can pull to dis-connect ?
Thanks for the advice.
I'm unfamiliar with electronics. Thought there's still something load running on the TDA1541 even with a non-connected analogue out. So, some of the power regulator (at least the one supplying TDA1541) will not get hotter when the CDP is running it's transport only ? If that's the case, I leave it as is. Thanks a lot.
