I was given a cd 303 .When i press play the cd spins for 10 seconds and then it stops itself.Also the cd timer does not work it is totally blank .Was told this is not able to be repaired can nybody help .
Thanks.
Thanks.
What does "the cd timer does not work it is totally blank" mean ??
Is the display always off ?
If so, the power supply is probably at fault.
Andy
Andy
