Philips bdv67d bdv66d replacement
I have been looking replacement darlington transistors Philips BDV67D and BDV66D.
The amplifier i want replace them in is rated 80w Rms at 4 Ohms (100w peak) per channel. There is one pair of these per channel. Toroidial transformer is 60 volts and 300VAC
Bought already fake ones, so i want modern replacement from known seller.
Specs:
Type Designator: BDV67D
Material of Transistor: Si
Polarity: NPN
Maximum Collector Power Dissipation (Pc): 200 W
Maximum Collector-Base Voltage |Vcb|: 160 V
Maximum Collector-Emitter Voltage |Vce|: 140 V
Maximum Emitter-Base Voltage |Veb|: 5 V
Maximum Collector Current |Ic max|: 16 A
Max. Operating Junction Temperature (Tj): 150 °C
Forward Current Transfer Ratio (hFE), MIN: 2000
Noise Figure, dB: -
So i found Sanken 2SD2083 and 2SB1383
Specs:
Polarity: NPN
Maximum Collector Power Dissipation (Pc): 120 W
Maximum Collector-Base Voltage |Vcb|: 120 V
Maximum Collector-Emitter Voltage |Vce|: 120 V
Maximum Emitter-Base Voltage |Veb|: 6 V
Maximum Collector Current |Ic max|: 25 A
Transition Frequency (ft): 20 MHz
Collector Capacitance (Cc): 340 pF
Noise Figure, dB: -
So will i get in problems with the power dissipation 200W vs 120W?
Any other things to consider?
