I'm building a small guitar amp, that I ran into a Philips AD8080 speaker, and it sounded very good !
I would like to find the closest modern substitute possible for these Philips AD8080/M4 or AD8080/M8 (dual cone, 4 or 8 ohms...).
Thanks for your help !
Manuel
Manuel
that might be these -
AD80800/M4S
http://cgi.ebay.de/Philips-Breitbae...39:1|66:2|65:12|240:1318&_trksid=p3911.c0.m14
low power !
less than 5 watts .
or these -
http://cgi.ebay.de/Philips-AD8082-M...39:1|66:2|65:12|240:1318&_trksid=p3286.c0.m14
http://cgi.ebay.de/Philips-AD12202-...39:1|66:2|65:12|240:1318&_trksid=p3286.c0.m14
65
AD80800/M4S
low power !
less than 5 watts .
or these -
65
Well, thanks for the links, but actually, I already own a bunch of them. What I'm looking for is a modern substitute for it, still in production. Is there anything close to that ?
What was your set-up, I often see these models on e-bay and I always wonder the set-up used since I am not able to find any t/s param anywhere on the web.
Do you run them open baffle.
Regards,
Eric
Regards,
Eric
I left them in their cardboard box....🙄 Works OK though...😎
I'm also looking for their technical characteristics to build a bass reflex enclosure : this may seems interesting ? AD8080 technical data
Bonjour Smile44,
These are intended for OB since the magnet is so small (high Qts), you may find something good by Eminence speaker, they have a whole section on guitar speakers, see link below.
Eminence guitar spkrs.
Salutations,
Eric
Salutations,
Eric
- Full Range
- Philips AD8080 substitute
