Hello,
I received two wonderful speakers Philips 9750 / M. I would bring them back to life by building an enclosure suitable to them. Only you can help me ... Maybe simple.... example bass reflex (audio nirvana docet), or MLTL .... I do not know ... give me suggestions ...
Forgive my bad English
Marco
Marco
Philips 9750
I would try a simple open baffle. If they sound OK on axis and you want to play louder a closed box perhaps. For bass reflex you need to be able to measure T/S parameters to get a resonable design (that or a lot of trial and error...)
DrBoar hello, thanks for your reply. the dipole is too big for my room. These are the specifications found on the net:
Diameter 8,5 inch (21,5 cm) - Deep 5,2 inch (121 mm) Impedance : 5 ohm
AD 9750 M
20-60-AH
Philips specs:
8 inch luidspreker from 1952 with hig efficiency
Produktcode : 49 239 51 - 20 60 AH
Philips 9750M with double wizzar 18.000 Hz
The magnet is 13.000 Gauss / 58.300 Maxwell
Efficiency : 10%
Imp: 5 ohm
P diss: 6
Res: 60 Hz
Freq: 18.000
Size: 21,6 x 21.6 x 12,1
Weight : 1700 gram Specs
Specs from the internet :
8.5" Overall Diameter
4.76" Tall
5 Ohm
Response rated up to 20,000 Hz
13,000 Gauss / 15,300 Maxwells
10% Efficiency (approximate equivalent of 102dB)
Re.....................4.2814 Ohms
Fs...........................69.98 Hz
Qts..............................0.532
Qes.............................0.561
Qms.............................10.24
Le.....................0.25mH (10k)
Mms.....................9.412 grams
Vas........1.453 ft^3 (41.14 liters)
if it is accurate, I do not know.
AD 9750 M
20-60-AH
Philips specs:
Efficiency : 10%
Imp: 5 ohm
P diss: 6
Res: 60 Hz
Freq: 18.000
4.76" Tall
5 Ohm
the cabinet audio nirvana created by David Dicks not and does not wish to follow the concepts T / S and it seems that the same sound good ... ��
Greets!
Based on these specs, a 152 cm tall x 870 cm^2 MLTL [~132 L] with a 56 cm driver offset [~seated ear height for many folks] and a 248 cm^2 baffle thickness vent down at the bottom looks good for a flat mid 40s tuning, good enough for most music at a reasonable SPL with a few watts. If up against a wall, then add vent damping as required. [all dimensions i.d.].
GM
4.76" Tall
5 Ohm
Those are my specs! I posted those to an eBay auction. That looks like the information from a NOS unit I sold a long while back.
These are my measurements for a used pair I also sold:
Re.....................4.645 Ohms
Fs.....................57.2 Hz
Qts...................0.581
Qes...................0.617
Qms..................9.976
Le.....................0.245mH (10k)
Mms..................11.66 grams
Vas....................49.71 liters
Cool, the MLTL still works, though with the lower Fs, some may want to tune it a little lower with a longer vent.
GM
GM
Those T/S parameters look pretty good. Start with a simple box and find out if the mid and high range qualies warrant a more elaborate effort.
The FR looks better than the 9710!
I would build a large box 50-100 L with two or three bass reflex vents and having plugs for the vents so they can be tuned differently or even converted to closed box. A whide baffle to help the level below 500 Hz up in output. It also adds to the vintage look...
I liked the 9750M a bit better than the 9710M. I compared them side by side, as well as in a back loaded horn.
Hi guys, thanks for the measured parameters. But here it needs a construction plan suitable to these beauties. maybe not too big or difficult or more expensive ... I ask too much? 🙂 maybe yes...
perhaps, it sounds good in a Jensen ultraflex.
or in this cabinet on diyaudio homemade presented by our friend VVXUAN.
carry the link of the discussion:
http://www.diyaudio.com/forums/full...mples-box-very-good-full-range-speaker-6.html
or you have to build something similar to the bass reflex cabinet proposed by audio nirvana ... you have your say.
http://www.diyaudio.com/forums/full-range/280522-philips-9750-m-help-plans-cabinet.html#post4472247
GM
hello GM you're right ... I do not know why I had missed ... you can have a design, a plan, to see exactly what you thought. how you calculated these measures?
Greets!
If you are asking for a drawing, I do not have one, just the information I posted, which is enough for you to build it, though you will have to decide what the width, depth is for the 870 cm^2 i.d. area and where to put the 248 cm^2 [17.77 cm dia.] vent.
If I built it, I would use the golden ratio 1:1.618.........width = 37.52 cm, depth = 23.19 cm and the vent down at 121.6 cm from the top [i.d.].
I design the various vented TLs based on basic T/S vented alignment and 1/4 WL pipe resonance theory.
GM
GM
- Full Range
- Philips 9750/M Help plans cabinet
