philips 150b6 15 inches lcd monitor
is it easy to strip this philips 150b6 15 inches lcd monitor it's power supply is embeded inside the unit
with dvi,,vga input
16ms response time
contrast ratio--450:1
is it possible to project a 130" diagonal image size using this 4:3
lcd philips 150b6 monitor
please help
danny
i tried to use a 150P2G and it has a ffc issue.
it's the greatest lcd response time i've seen so it's too bad.
anyways, i can't remember exactly but i think an extension might make it work but it's a bit difficult. the design was something like " the circuitry that went to ffc HAD TO sit Behind the lcd panel where the backlight goes.
i don't recommend a 150 philips anything since it might be similar.
