phase inversion of audio
I would use an inverting buffer. A standard op amp with the signal on the inverting input will do it.
Non inverting; use the + pin as your input.
You already have it: the circuit posted by Jon Snell, with R1=Rf , value can go from 10k to 100k each, 741/TL071 fed +/-15V
EDIT:
Cortez's link shows it in more detail and the practical Protoboard test.
