Pepco Paul Guitar Amp AC wiring
I'm restoring this amp. It lacks a power transformer so I'm rewiring it with an isolation transformer. (A 3 prong cord was already installed)
I noticed that the volume control puts the excess signal to the mains?!?!? Should this go to ground instead?
Any other safety things that should be done to this amp?
I'm figuring the mains side of the isolation transformer is the side that should be switched and fused.
That circuit is insane. The node A is the audio common. Yes, fuse and switch on the primary.
Your isolation transformer secondary should feed the half wave rectifier diode and 50uF capacitor.
Reroute the input stage common to node A.
Without an isolation transformer...the amplifier ground is connected to a city power connection. And so you think the volume is connected to the power. Connect the transformer and do not touch the circuit combination.
The reason. of rayma.. Advice...... is electric shock if someone touches the metal part of the volume . So... said, disconnect the volume from the ground line ... or live electricity..This is not a signal to power.... 😒
