Hi all, I have picked up a pair of Alpair 7.3 and must now decide on a cabinet design. The amp is a JE Labs design SET using KT90 in place of EL34, probably putting out 8W. I typically listen to jazz trios, female vocals, folk music, but also enjoy Zeppelin and Pearl Jam when the mood strikes....
The room is 14 x 18 and opening into a smaller dining room on one end. WAF will be a factor. I have a woodworking shop so other designs are possible.
Thought I would seek advice before I start the saw.
John
John
They are both good. I'd personally choose FH3 -- you should ask the wife which one she likes.
dave
Note that we have both here.
dave
dave
the Pensils are a pretty darn simple build, but I'd agree that if WAF approved, the FH3 would be my choice between the 2
I have Pensils in one of my own systems - and as much as mrs B likes the look of the FH3, they're only good for short visits and demos - they don't "disappear" enough
there is a builder's photo gallery that you might want to show your wife
http://www.diyaudio.com/forums/full-range/199849-frugel-horn-mk3-picture-gallery.html
now if she's a music lover show her this post in particular:
http://www.diyaudio.com/forums/full-range/199849-frugel-horn-mk3-picture-gallery-5.html#post2951478
That sounds like a good recommendation! Would there be a significant change in bass response if I used a "fonken-style" cab? I confess to liking strong, but well defined, bass at times.
John
John
John
"MarKen" would have perhaps more "finesse" from the lower mid-bass down, but lack the impact and weight of either the Pensil or FH3 with the 7.3 - I can definitely see many folks sensing the need for woofers with the MarKens.
of course, I should say - "build both, then decide"
that's a T-shirt I definitely have multiples of
With Led Zep. on the table, powered woofers and a lot more than 8 watts.😀
jeff
I should have come clean earlier, I am a CD user. That said, my 8 watts sounds pretty good so far! I am intrigued by the MarKen "finesse" and really only enjoy bass when I hear it but not feel it. Are the plans for sale at Planet 10?
John
John
John
some are free,
p10 hifi | Box Library / Mark Audio
others here
http://www.diyaudio.com/forums/plan...10-hifi-minionken-plan-set-subscriptions.html
that's OK, we don't judge harshly here - some of our best friends are users
Pensil vs Mar-Ken
After comparing the Pensils and the Marken 10.2 directly in the same system I am more impressed with the Mar-Ken. The reason is that it gives better cone control and sounds great within it's entire range. Although the pensils can go a little lower and with more efficiency, the extra range offered is not really worth tackling with this driver in my opinion. Especially considering the use of lower power amps. Of course it depends on your system, I use mine for music and home theater. Movies tend to be unpredictable in the bass region requiring the use of a high pass filter. In this situation the pensils are overkill, but they are floorstanding which may be a major advantage. Somehow the Mar-Ken cabinet flattens the impedance on the driver a lot. For me with my DSP this was a huge advantage that ultimately allowed the amplifier to push the extra power to the driver's low end to produce the sweetest sound I have heard from this driver. If I were to do it all over again, I would use the 7.3 mar-ken high passed at 60hz with a powered subwoofer.
I still need to hear this FH3 so no comment on that.
yup, that's pretty much what we've said about the Fon / Mar ken style cabinet vs more standard BR or even most MLTL implementations; while the latter types can squeeze more weight / impact / slam - pick your favorite descriptor- the resistance of the multiple high aspect ratio ports, coupled with the inherently high degree of bracing and small enclosure dimensions compared to a floorstander MLTL go a long way to resolving finer texture of inner detail and "DDR" (to use a "Dlugism" )
I'd experiment as high as 120Hz when using the 7.3 in a HT system
The FH3 is a completely different kettle of fish
Guilty here too!
I can say for my taste, the Mar-ken cabs i've built have all been very satisfying
re: bass quality.
Quantity might dictate something else, but you can always add a (couple) of subs if req'd.
Good Luck with the process.
Don
re: bass quality.
Don
...and "DDR" (to use a "Dlugism" )
Allen Wright gets all credit for this term.
dave
- More Vendors...
- Planet 10 hifi
- Pensil vs. FH3 with Alpair 7.3
