Pelonis M42 amplifier problem
hello,
I've picked up a pair of Chris Pelonis model 42 mk2 speakers and amp, used them for a while, then rearranged things a bit and changed power cables.
when I plugged them in the light went on, then out, and now theres no life in the amp.
usually there should be no problem with polarity, and the cable works fine for other things.
has anyone else had the same trouble?
is it just the switch??
there is no fuse.
I'd really like to fix this, as these are great little speakers, which I've dialed in to be flat from 20hz-20khz in my very small and well treated space.
Chris didn't have any suggestions when I heard from him before, and when I picked up the problem later I have received no response.
drawings are not available.
thanks
https://www.chrispelonisspeakers.com/model-42-mkii.html
