I'm looking to make a small sub to fill in for where my ceiling speakers are lacking. Space is an issue (wife isn't as into this as I am), so I was planning to make an enclosure as small as possible.
A passive radiator seems like the way I'd like to go, and I noticed these:
Peerless by Tymphany 830855 Peerless SDS-106 subwoofer | Loudspeaker freaks
Peerless by Tymphany 830878 Peerless 3,5 inch passive radiator | Loudspeaker freaks
They seem perfect, but I think something is screwy with the datasheet for the PR. Do I not need Vas, Qms, and Fs?
Even looking on the Tymphany website, it looks like the datasheets for all the passive radiators are incomplete:
Driver Search Results | Tymphany
Am I completely missing something? I was tempted to just spend the extra tenner and buy a second regular driver, and running it as a passive radiator, just because I'll know the parameters I need, but then I'd have to figure out how to add mass to it.
Any ideas?
James
Any ideas?
James
I'd go with a larger subwoofer, and mount it in the ceiling. Check out the shallow-mount 10" sub from Parts Express, for example.
Thanks, but I don't want to cut up and cable into my ceiling.
I'm just after figuring out how to build an enclosure for those (or similar) drivers. I've also not done a passive radiator before, so was looking forward to trying that.
Hi All,
No! Try a f0rmula or a few more. FYI:
b🙂
b🙂
A 4" driver with 3mm xmax and 63hz fs in a tiny passive radiator box is barely going to fill in much at all unless your ceiling speakers are absolutely tiny and inefficient.
You would do far better with a decent 6.5" in a sealed or PR enclosure or even a sealed 8 as the box can be quite small with a decent driver.
Then find a good place to hide it in a corner or behind something. You could even use some creativity in making it look like something else or build a flat sub under a couch.
