I want to build cabinet for this 3 inches fullrange to be used as midrange driver. My main interest for this driver is from 200Hz and up as I have a separate active woofer .
Tweeter is Peerless XT25SC90-04
I will be using the active crossover from Elliot and my room is about 200sq ft with ceiling height of 10 ft. Listening volume is up to 93 db at a listening distance of 6 feet.
Please advise the crossover points between the mid and tweeter and a suitable stand mount cabinet size
On line simulation software suggest box volume of about 8 litres with a 2.5 cm port diameter and 4 cm port length. Is this cabinet reasonable compromise ?
Pdf files of the driver datasheet below.
