Peerless K010DT Tweeter info.
As the title suggests I'm after the technical specs of the defunct Peerless K010DT. I know the voice coil is 1" and the impedance was 8 ohm, but I really need the sensitivity, or better still the datasheet. Cheers.
The name is really KO (as in Oasis) so KO10DT
This is advertised as a replacement unit:
https://www.hifikit.se/komponenter/hogtalarelement/115dt26-27.html#horizontalTab2
This seems to be the spec sheet at the time of its active producdt life. A lot of distirsion as I recall it but it was what available at the time...
http://user.faktiskt.io/paa/KO10DT.pdf
