Peavey XR 1220 powered MXR
This is one of the newer makes of this MXR. Class D. I need this schematic for the newer version of this amp. there is no output from the MOS FETS. but i do have signal on the head phone jack which tells me pre amp is working . So no signal out of power amp section. Please if someone has this schematic , please send it to me. Thanks so much one and all.
The bad thing is , im really not set up to do class D repair. As you need at least a 500mehg scope and a isolation tranformer to boot. I may send the board to Peavey if they will repair it cheap enough. Enzo as always thanks for help. I did get the schematic tho.
