Hi there,
I'm working on an old Peavey CS-200 mono power amp (not to be confused with the CS 200x). It has been hacked at in it's past and I'm hoping to put it back to stock or even improve it, a bit.
Does anyone have a schematic for this amp? It is not readily available online. The CS-400 is drastically different and no help.
Thanks!
Thanks!
Write to Peavey Service and give your serial number so they know which revision you have.
You may get lucky.
You may get lucky.
You may get lucky.
Good idea. Thanks.
Proper address is customerservice@peavey.com
Better yet, CALL them on the phone and ask for customer service.
Any Luck with your CS200? I have one, not working but keeping it for nostalgia?--I don't know..
In fact, yes! I haven't touched it for a while now, but it does work, now. Peavey tech support sent a schematic right over upon my email request. It even includes some hand drawn layout diagrams and engineering notes.
Hi Kanurys;
I was about to cannibalize mine for some power resistors, fortunately I found some elsewhere. I will fix mine someday, I'm sure it will be a collector's item one day at least for Peavey fans.
Any possibility of getting a copy? If it can't be posted here, I could pm you email address.
Thanks, Peter in Hillsdale, Ontario
Nothing stops us from posting here, but by the same token, nothing stops an email to customerservice@peavey.com to ask for a copy.
- Live Sound
- PA Systems
- Peavey CS-200 Schematic
