Pearl - one channel down
Hi everybody
My wonderfull pearl suddenly stopped playing music in one channel - that is, only a very faint signal was heard.
All voltages check out OK, except Q4 (small ZTX450 which supplies the 2sk389 jfet in the output with power) - which reads 0.8 instead of 13.8 volts.
As mentioned, all other voltages marked on the board reads OK, including the 9 volt reference point.
Any ideas? Is it simply a matter of "swap ZTX450 to a new device" or should I look elsewhere?
Best regards
Hans
Unfortunately, swapping the ZTX450 did not change anything, same result -about 0.8 volt on the emitter.
What could cause this - a burned jfet output device, which then shorts/overloads the ZTX450
Dont know if it makes any sense to measure the JFET output device, since the device supplying it seems to be down?
Best regards
Hans
Yeah, this is the typical problem: the K389 blows and takes the ZTX with it; replacing only the ZTX means it will blow again.
For those that slowly run out of K389, one can replace it of course with K170BL or K369GR. In fact they don't even need to be matched devices as they are used in parallel (no distortion cancellation going on).
If one intends to replace the K389 with K369GR one should keep in mind that the K369 has a smaller pinch off voltage (and therefore also a larger transconductance) so produces slightly more distortion. One can remedy that by using a slightly larger degeneration resistor.
Enjoy, Hannes
