See "Strange problem with Pearl 2 and SAE cartridge."
I was one using this MC cartridge, and installed the described circuit to allow proper operation.
I am now looking at other MC cartridges, namely the HANA SL among others.
Assuming otherwise compatible with the Pearl 2, will I need to remove the snubber circuit, or is it harmless with a cartridge that doesn't require it?
Russellc
Russellc
Reading the above mentioned thread, it is a zobel network, not a snubber as I called it. I also see in the post revealing the cure, Wayne is said to say that such a zobel is on the various Pass phono preamp, so I am thinking the HANA SL should be fine as is. It would be easy enough to try both ways.
If anyone has a thought on this, much appreciated!
Russellc
Russellc
Shouldn’t be a problem at all usually like 680 pf and a K works fine.
That's exactly what I was told to put in there, so that is good news and I will leave it as is.
Thanks for the answer,
Russellc
