PCM17xx Family DAC Programming
Hi. It is surprising that with the popularity of the Texas (lately BB) family of DAC usch as the PCM1738, with ot without external filter such as the DF1704, I can not find example of program code to use these dac.
I'm pretty sure it is trivial for some of you guys.
I'm looking for example of PIC C-Code if possible.
I know already how to push on the serial line byte of data.
How do I access the different registers into these DAC?
Is there a better sequence to load them?
What is the best code sequence, First mute, theb set the different regiter then unmute, etc...
Please I need help. Thanks...
SB
