PCB Vendor
I'm looking for a high quality mil-spec/industrial type vendor for boards. This is work related, not DIY related.
We all know the quick turn proto houses and I use them but for this I need;
600mm x 600 mm
G10 or G11 material
10+ oz/in thickness.
nickel plating would be great.
This is low quantity.
Thank You.
For group buys on head-fi / head-case we used to use imagineering (pcbnet.com) back in the day. They were out of Illinois back them (2000's), were expensive, and were very good quality. This was before all the chinese pcb proto vendors. I don't know if they offer the capabilities you are looking for however.
Sorry to hear for you and your country.
In the past remember using ACI and advancedpcb
I used imagineering once for a 4-layer design
Problem with these on-shore suppliers is the large NRE fees for setup.
