• The Vendor's Bazaar forum is for commercial offers and transactions. Only unmoderated members can post here.
PCB mounted RCA connectors, gold plated brass with Teflon insert
Neurochrome.com
Joined 2009
Unlike other PCB mounted RCA connectors, these high-end connectors have round pins. This greatly simplifies the PCB layout and results in a much better connection to the circuit board.
The materials used:
  • Body and contacts: Gold plated brass
  • Centre insulator: Teflon
  • Lock washer: Gold plated steel
  • Nut: Gold plated brass
Max supported panel thickness: 4.0 mm. The threaded bushing measures 8.8 mm from the body to the tip of the threaded bit.
I bought a bunch of them and will be selling them by the pair (one red, one black) via my website: www.neurochrome.com
Thanks,
Tom
