Anyone know if these exist? I want a right angled connector like the one below...
...but this gender?
Do they exist? I would rather a UK distributor.
...but this gender?
I've never seen a male PC-mount RCA connector.
I've got to ask ..... why do you need such a connector?
Hi, maybe this will help
RCA to RCA Phono Plug Adapter / Joiner Coupler MALE B09 | eBay
Best regards.
Best regards.
I'd like to know what the application would be also. I can imagine a small handheld circuit test tone generator with a plug out the end to stick into input jacks on a receiver maybe. Or even a signal detector made similarly to test outputs. But possibilities abound.
This is the closest thing I could find. The end could be cut or filed to fit through a hole in the PCB.
http://www.switchcraft.com/Drawings/3501MCX_CD.pdf
Thanks for the suggestions. I want to use them to mount my minidsp into a motherboard of 4 amplifier channels and pre. It will become a integrated amplifier for active speakers with the USB interface for configuring the minidsp. I didn't wan to use male adapters because it will be too big and didn't want to mod other connectors because I want it professional. I might just mount the dsp on stand offs and use patch cables with male connectors on the end.
Thanks anyway
Thanks anyway
- Design & Build
- Parts
- PCB Mount Male Phono Connectors?
