Hi
I recently started learning how to design PCBs and using Google found the programs 'TinyCAD' and 'FreePCB'. It seem though that FreePCB comes with a very limited set of packages in the footprint libraries. For example there bare no transformers, or bridge rec's etc..
Where can a get a competent set of footprints to start designing with?
I use ExpressPCB. It is footprint challenged as well but a new footprint is easy to create. I make sure I'm on a .010 grid and snap is on. .010 works for english or metric (.040~=1mm) components, in most cases.
Both of those should have something that you can start with in the download package. Any bizarre parts.....make your own footprint.
if you can deal with the demo/evaluation limitations Eagle has very extensive part libraries
http://www.cadsoftusa.com/freeware.htm
so extensive that KiCad (unlimited, open source) users developed a import function
FAQ - KiCad
FAQ - KiCad
