hi all,
im a newb and need a little help. im not sure how to separate out my sub channel on a basic 2.1 stereo setup from a dac.
my rig is like this
pc sound card > toslink > dac/headphone amp/pre amp > amp > 2.1
my question is how do i separate out a sub channel from my dac, which only has two pre outs? do i need to change my set up or can this be done with my existing set up? i mayyyyy, just thinking about it now, be able to run a sub output from the pc card to the amp and from the amp to the sub but im not sure if im a fan of that or not yet. anyway...
let me know your thoughts, please ask any additional questions.
cheers to all helpful answers.
my rig is like this
2.1 requires a dedicated multichannel soundcard, which also does the upmixing for normal stereo sound.
In your case, you would need an active crossover after your dac/headphone amp that forks a mono bass from the stereo signal to your sub. You can certainly diy something like that, check Rod Elliotts pages.
Hannes
Hannes
has anyone got any suggestions on an active (i assume 3 way) crossover?
im thinking something like this http://www.siliconchip.com.au/cms/A_30278/article.html
