Passive summing with volume control.
Hey all, i am new to forum. I am trying yo build a passive box to sum 4 mono 3,5mm jack into 1 3,5mm jack . It all has potentiometer on each. Now;
Signal flowing on ch-1, but when i change other “empty” / “no signal flowing” channel’s pot the flowing channel’s level changes. Every channel has 2k resistor on middle leg of pot. Potentiometer’s are 10k value.
I know i will loose some signal. But need to figure that other resistor affecting system.
What to do?
I managed to do a circuit with tl072 on breadboard. But it works really loud humming and noisy. Am i doing sth wrong ?
Dual +- supply ? Try 10k Resistors.
The picture from Rayma shows 0V, but this is Your ground. You still need the + & - supply.
Unity gain Inverter added ? If not reverse speaker wires.
Shorting inputs to ground what happens ?
Powered opamp with 12v supply , + to pin8 , - to pin 4.
input to 2nd pin. 3rd pin to ground , 2.2 k resistor to feedback loop.
No inverter added.
Shorting input and ground if i am not recall wrong the signal lost. But when even no input
The opamp makes noise just with power pins inserted.
