Passive radiator
Simple question:
Can a passive radiator incorporated into a subwoofer enclosure increase efficiency? Or is adding dynamic mass to the system, rather than just moving air, a reduction in efficiency but perhaps beneficial for directionality?
Is an "omnidirectional" passive enclosure -- for example, a 12" subwoofer mounted in a front baffle and housed in a framed "sealed" cubic enclosure with a compliant skin of some sort, e.g. latex or something with a relatively low modulus of elasticity, stretched taut across the five other sides worth experimenting with?
My understandings of passive radiators while limited is somewhat similar to "ported" alignments...first off, yes, one will increase efficiency with a PR. I don't know of the formulas or simulation programs to engineer the PR system, I'm sure someone here has the formulas...I'd bet real monies the enclosure sizes will be immense, a cubic meters worth at least. Fabricating your own PR "membrane" will consume vast amounts of experimental time & effort.
-------------------------------------------------------------------------------------------------------------------------------------------------------------Rick...
