Hi all
I have a very high quality Penny & Giles pot I acquired from a previous employer when it shut down, it was custom built for the speaker ouput control in a £400K mixer. I think the pot itself cost us £200 at the time from P&G, hand made laser trimmed etc as I recall. It has very accurate channel balance , thats why it was so expensive, 0.1db from what I remember.
Anwyay I fancy knocking up a passive pre using it. Its 10K log (hope its log anyway trying to find the cct it was used in..).
I would be connecting it between cd player and the input of my power amp which has a 33k imp.
Would this be ok? Or will I get hf trouble? I seem to remember last time I looked into passive pre it was advisable to use high impedance pot.
Advice welcome.
thanks folks ;-)
Advice welcome.
thanks folks ;-)
Sounds fine. You should be able to confirm the log characteristic with your multimeter. Higher impedance pot is not preferable unless you have a very anaemic tube source.
great . thanks.
yes i will measure the pot. im at work now so its not here. i found it under the stairs other day and thought hmmm i should do something with that ! 🙂
