Passive Monitor Switching Questions. (Noob in need of advice)
Hi everyone.
I was considering building a basic monitor switcher and volume controller (Source & Output selector) based on this well known article.
http://www.proharmonic.com/articles/AT78_OTB.pdf
It is in short a standard passive device that routes balanced audio through a set of switches and pot's to control source / level / output.
It's meant to be a small desktop unit that will sit next to my keyboard to switch between my active JBL LSR's and NAD amp running my NS-10s.
My Question is, what are the major disadvantages of this type of passive design? I know there is quite a lot of info on this already but Im getting conflicting opinions and the article seems to dance around known issues.
1. Will there be a problem with stereo imaging if using a quality dual gang pot for the volume control (20% tolerance. Bourns 91A)? If so, to what extent can I expect problems and what can be done to solve this without using one of those expensive goldpoint switches?
2. Will there be an issue with the source and output selectors causing a "pop" on my monitors when being switched. Will this potentially damage anything in my chain? I'm considering using the common "white and black" 4 pole Lorlin switches for balanced operation.
3. Im not all that worried about a potential drop in level (I've been told to expect around -6dB) but will this design impose any other undesirable artefacts on my monitor signal?
4. Is there a better way to build a simple passive switcher? I would prefer it to have a volume control on it.
Thanks a bunch
Richard
