I am currently in the middle of construction of my A-75 amp. A question I have is the BOM. The paperwork which arrived with the pcb's from AudioExpress has several wrong numbers associated with the resistor locations. The pcb's also have errors.
Is the information which is available at the Pass DIY site accurate?? The main discrepency is with the r-22,24,21 locations.
One other question -- when using thermistors for the resistor part of a crc power supply would it not be better to parallel two on each rail. The leads are not too terrible large and I do not want a current restriction. Thanks Tad
tryonziess,
About your CRC with thermistors:
The thermistor is choosen for the exact current going through
Too much current it goes overheating and can break
Too low current and the internal resistance will stay too high
Example: Keystone CL60 = 10 ohm cold value and a 5 amp current rating
mounting 1/2" over the circuit board ....
You will have to try, and if you want to parallel some
just roll the pins over the one soldered on the circuit...
regards.
Alain.
regards.
Alain.
Alain Dupont said:You will have to try, and if you want to parallel some
There's no rule against paralleling thermistors, but they do exhibit
current hogging when heated.
