pass F5 superturbo with 10 pairs of output mosfets?
I would go with either source or emiter followers in between FE and OS , but fine-tuning of said iteration is not for faint at heart ........
your easiest bet is to double input JFets , halve drain resistances and that's it
stay with up to 10 pairs in OS
but is the driver sufficient to drive those many mosfets? what is papa using for the X series amp? I believe toshiba mosfets.. some J132 or any other ones. I also read somewhere that papa says its better to driver mosfets with mosfets than with transistors as mosfet drivers sound good with mosfets.
