Parts to keep in stock
Well thats a pretty broad question and would definantely depend on what kind of amplifiers you will be working on.
If you are going to specialize in 1 particular brand easy answer, but if you plan on servicing every type in the book than thats a large list and you better be ready to spend some bucks!!!
This may have been the list. It needs to be updated a bit but should be of some help.
Commonly Used Parts
Generic (applies to MANY amps):
* For amps that use SMD resistors, keep a good selection of sub 1000 ohm 0805 resistors and sub 500 ohm 1206 resistors.
* For most all of the amps below, the IRF3205 is a good sub for PS FETs rated greater than 50 amps. The IRFZ44 is a good sub for PS FETs rated for 50 amps or less.
* For amps greater than 10 years old, you may want to replace all of the electrolytic capacitors. These will vary too greatly to include suggestions for replacements here.
* PS driver ICs TL594 and SG3525 will cover most amps. SG3524 and SG3526 are also common but are rarely needed.
* For generic amplifiers, the power supply gate resistors often open or change value. Stock both 1/4 watt and 1/8w of 10, 27, 33, 47, 68 and 100 ohm resistors.
Rockford (older punch BBQ and Batman style amps):
IRF540
IRF9540
IRF640
IRF9640 (larger amps)
0.1 ohm 3 watt dale 1% resistors (LVR03R1000FB12)
MMBTA06
MMBTA56
20 ohm SMD 0805
10 ohm SMD 0805
100 ohm SMD 0805
51 ohm SMD 0805
39 ohm SMD 0805
Rockford (newer Px002, etc.):
FQA36P15
FQA28N15
0.1 ohm 3 watt dale 1% resistors (LVR03R1000FB12 - very good for any amp needed a 2-3 watt emitter/source resistor)
MMBTA06
MMBTA56
20 ohm SMD 0805
10 ohm SMD 0805
22.1 ohm SMD 0805
100 ohm SMD 0805
51 ohm SMD 0805
39 ohm SMD 0805
Rockford (older BD):
IRF3415
IRF6215
15 ohm 1/4w axial resistors
24.1 ohm 1/4w axial resistors
10 ohm SMD 0805
MPSA56
MPSA06
TL072CD
LM6361
LM6171BIN
LM6172IM
MIC4420CT
HCPL2211
Kicker (older ZR series):
TIP35C
TIP36C
RFG70N06
TL071CD
TL072CD
MTX:
IRF3415 (for smaller class D outputs like in the 6500d)
MPSA56
PZTA06
PZTA56
10 ohm SMD 0805
47.5 ohm SMD 0805
NE5532P
NE5532D
ES2D diodes
Orion (older):
2N6488
2N6491
NDP7060
10 ohm 1/4w axial resistors
MPSA56
MPSA06
JL Audio
IRF540
IRFZ44N
47.0 ohm 1206 SMD resistor
75.0 ohm 1206 SMD resistor
100 ohm 1206 SMD resistor
200 ohm 1206 SMD resistor
SoundStream (older)
TIP102
TIP107
2SA1562
2N2222
0.27 ohm 2w axial resistors
3.3 ohm 1/4w axial resistors
34 ohm 1/4w axial resistors
well, small list. been trying to track what i keep in and use., but no where near a real list....
resistors: 22ohm, 27ohm, 33ohm, 47ohm, 100ohm 1/4watt. for power fets, and some outputs. i think 1k is popular size.
irfz44n, irf3205, irf640, irf9640, irf540, irf9640, irfp064n, 12p20, 19n20, sg3525an, tL494, (lots of tip102 and tip107 if you are doing old school soundstream reference s/sx) tip35c& tip36c, tL074c, irfz48v, 31n20d.
these are just a quick list of what i use, and you may need different, so take this at your own risk. there are also a few drivers i left out, and couldn't recall.
