Welcome to ZC's official garage sale round two.
Lots of capacitors this go round.
(3) Mallory 10,000uf 100VDC screw terminal type caps 2.5" x 4" long $20.00 for all 3
(2) Sprague 10,000uf 100VDC screw type caps 2.5" x 4" long $10.00 for the pair.
(2) Mallory 3,000uf 50VDC screw type caps 35mm x 65mm overall $5.00 pair
(4) Mallory New in box 22,000uf 250vdc caps. 3" x 9" $50.00 for all 4
(Many) Mallory 1,500uf 450vdc screw type caps 3" x 5.5" caps $2.00 each
(Many) Mallory 800uf 450vdc screw type caps 2" x 4.5" $2.00 each
(1) Pyramid Dual Section Can cap 40uf x 2 @ 450vdc common neg. this mounts into 1/2" hole with a single nut and has 3 terminals on the bottom. tube style. $4.00
(1) Pyramid Dual Section Can cap 20uf x 2 @ 450vdc common neg. this mounts into 1/2" hole with a single nut and has 3 terminals on the bottom. tube style. $3.00
(1) Pyramid single Section Can cap 10uf @ 450vdc common neg. this mounts into 1/2" hole with a single nut and has 2 terminals on the bottom. tube style. $2.00
Transformers
NEW - Triad
115V - 32VCT @ .25A + 15.5VCT @.75a
$5.00
Berkshire Transformer Corp. TF1RX13FA
6000 ohm 50madc 250pwv - 8 ohm 5 watts 175 pwv
+/- 1dB 50-5khz Max alt 40,000ft
$5.00
Basler Electric
115-115-140-24v rating unknown (small)
$2.00
Foss Electric Power SUpply PCB with Toroid $8.00
Transduktor DK-4352-C
PRI 50hz
110-110V
Sec.
200v .03a
33v .3a
15.4 1a
14.7 .5a
8.8 3a
(2) Acopian AC-DC Power supplies 5EB100
5V @ 1 amp +/- .25% regulation - 1mv ripple
Retail cost is $95.00 each asking $20.00 each or best offer. These appear new.
(2) Crest Audio CA4 output sections with heatsinks
each section has 8x TO-3P output devices that ppaear to be 2SC3281's, very hard to read lettering. These sections came from an amp with a fried Power supply PCB and are believed to be in perfect working condition. $50.00 for the pair or best offer.
Crest Audio CA4 chassis with BIG toroid. Specs unknown. chassis and Trafo only.
$50.00
Pair - new 43mm large silver frosted aluminum knobs $12.50pr
Pioneer Turntable headshell with unknow cart $5.00
All prices are plus shipping. Paypal only please.
Stay tuned for more to come.
Transformers
NEW - Triad
$5.00
$5.00
Basler Electric
$2.00
PRI 50hz
110-110V
Sec.
200v .03a
33v .3a
15.4 1a
14.7 .5a
8.8 3a
$50.00
