Parts for Dynaco-based ST-35 mono amps/w MagneQuest OPT’s
  • Thread starter Thread starter Deleted member 537430
  • Start date Start date
D
After a long period of deliberation, I have decided to sell amplifier parts that were going to be used towards mono versions of the Dynaco ST-35. I had been accumulating parts over the last 4 years or so and decided to let them go. Initially, I was going to try to sell the parts separately, but life’s too short to agonize over this way of doing it. That’s why I’m selling everything - all or nothing.
Parts are included for Gillespie’s EFB for individual bias of each tube. Also, parts included for tube rectification. Original was solid state.
(2) MagneQuest MS6 nickel pinstripe OPT’s - perfect for any push-pull EL84 amp that requires 8 and 16 ohm taps. Never used, just looked at! $500 - 10% = $450
Vacuum tubes - (4) SOVTEK EL84M — matched quad, never used. $80 - 10% = $72
(4) NOS GE EL84 — matched quad, never used. $100 - 10% = $90
(4) TAD EL84-STR — matched quad, never used. $100 - 10% = $90
(2) EH 12DW7 — never used. $50 - 10% = $45
(4) NOS GE 12DW7 — never used $70 - 10% = $63
(2) TUNG-SOL 5AR4 — never used $80 - 10% = $72
(2) NOS GE 5AR4 — hard to find at a decent price. $100 - 10% = $90
MONO PARTS
(2) Hammond 270DX
PT’s - 550 VCT (275-0-275), 5V 2A, 6.3 V 3A. $180 - 10% = $162
(2) Hammond 159S chokes - 4H 225mA. $60 - 10% = $54
(2) Clarity Cap TC600 film power caps - 4 pole 70uF 600VDC. $90 - 10% = $81
(2) Clarity Cap TC600 film power caps - 4 pole 50uF 600VDC. $80 - 10% = $72
(2) Clarity Cap TC600 film power caps - 2 pole 55uF 600VDC. $60 - 10% = $54
(2) Neotech NC-P311 male power cord connector. $40 - 10% = $36
(2) Neotech NC-P302 female power cord IEC. $40 - 10% = $36
8’ DH Labs Encore 14 AWG power cord w/ screen. $40 - 10% = $36
(2) Eichman Phonopod RCA plugs. $60 - 10% = $54
(2) Furutech FI-03 IEC fused power inlet. $40 - 10% = $36
All resistors (Allen Bradley, Mills, TKD, Caddock, etc.) caps (Russian PIO, Musicap), trimmer pots, switches, solder tags, mounting rings for Clarity Caps, wiring (Jupiter cloth, Neotech solid core, etc.), screws, washers, tube sockets, everything needed for complete mono amps (except chassis) will be included free of cost if you want everything that’s been listed.
As you can see, I have taken 10% off everything which I think is generous since everything is new. Amp parts comes out to $1071, and tubes another $522. (The one exception I’ll consider is to offer the amp parts separately and tubes separately.)Total cost would be $1071 + $522 = $1593. For $1500 you can have everything.
