Parts-Express.com: 2" Full Range Aluminum Cone Neodymium Driver | 2" Full Range Aluminum Cone Neodymium Driver line array midbass woofer 2" driver shielded woofer midwoofer
probably be as good to just go the the webpage and search for 289-124
With a line aray of 2" drivers where would the comb effect show up?
combing ? everywhere.
a better 2" is the peerless 830970 for $7.80 each and free shipping if over $100.
I've seen this come along a few times, could you point me to a link where I can read more about this? I have a plan for a large FR line array for in my HT....Make it a focused array and comb filtering problems are no more, but only for where you sit.
Heres a couple links. I have some info on My blog
They do need sufficient air flow. If you front mount them to 1/2" or thicker material with a chamfer the rise at ~1.5khz is quite large.
Rough measurements on the 2 aluminimum buyout. - Techtalk at Parts-Express.com
289-124 2" aluminium cone smoother then before - Techtalk at Parts-Express.com
http://www.diyaudio.com/forums/full-range/145575-parts-express-clearance-2-full-range.html
- Full Range
- Parts Express Buyout
